8 hp prop
rjn cajun
I need some help as I`ve never owned a motor before. I have a 8hp yamaha 1992 and I need a knew prop. The only numbers on the prop are 8 1/2x 7 1/2 and what appears to be a sideways V or an N Is there any other numbers to match up maybe somewhere else?
steelespike
Re: 8 hp prop
The prop is 8 1/2" diameter X 7 1/2" pitch Look up props for your motor in that size.
The key number is the pitch the diameter will follow and may vary slightly.
rjn cajun
Re: 8 hp prop
Thanks for the info. Now that I got that figured out. Does anyone know a good place to buy a prop for cheap. I typed my info in here at iboats and nothing came up.
