80 hp OB wiring schematic
Carmstrong
anybody have a wiring schematic they can send me for a 80 hp Mercury Marine outboard? #146383
I'm currently at the water working from my mobile device not my pc
Thanks
carholme
Re: 80 hp OB wiring schematic
Are you sure that is the s/n? Are there any letters in front of it? How many cylinders are there?
Gerry
Carmstrong
hi Gerry
oops sorry about that
OB146383
It's a 3 cylinder
thanks
Carl
Carmstrong
Thanks Gerry
I got both, great help,
really appreciate it,
Carl
Carmstrong
ok I'm trying to figure this out someone replaced the stator assembly on this beast which is red in color
however I see that they've got the wires hooked up wrong
The CDI wires coming off of the assembly are green with a white stripe and white with green stripe the available terminals at the switch box are red or blue
wondering which color CDI wire goes to these terminals or does it really matter if they're reversed?whoever installed it had the white with the green stripe wire going to ground
hopefully the stator assembly hasn't been damaged
did a resistance test and that appears to be ok
any help on this would greatly be appreciated
thanks Carl
