80 HP Speedifour
montyburns
I have a '67 Evinrude 80 HP Speedifour on a 16' Crestliner. The prothat when I try to get the boat to plane, it will plane for about 5 seconds blem is and start running rough and then I lose the plane. When I checked the plugs, 3 are burning perfectly with 110 compression in each cylinder. The Number 4 cylinder shows a wet plug with 100 compression(Checked compression cold)I am getting a spark on this wire. I just changed and set the points and condenser as recommended. Same result. Fuel mixture is 50:1 . I am stumped! This is a V4 engine, why wouldn't another plug be wet also? Would this eliminate a carburator problem? The motor starts very easily and idles fine. I even reversed the low speed jets, no difference. My service manual says there are no High speed jet adjustments for this motor. My friend thinks it may be a loose reed valve. About a month ago, I had the boat going 25 mph for about 15 minutes at about half throttle. If I increased the throttle it began to hesitate. A loose reed valve? I doubt it. The engine also has blue silicone on the suspect side of the cylinder head( same side as cylinder 4). My neighbour figures this may be the problem. I spoke to the previous owner last night and asked him if he put the silicone on the motor. He said no,and the motor always responded well for him. I guess I should remove the head or is there something simple I'm overlooking? Thanks for any info, Monty
F_R
Re: 80 HP Speedifour
Lets think about this for a minute. One set of points fires two cylinders. One side of the two barrel carb also feeds two cylinders. So neither of those items would affect only one. I'm not sure which cylinder the fuel pump pulse hose goes to, but a leaking diaphragm would flood whichever cylinder that is. Water could be getting in the cylinder. A bad spark plug could be the culprit. Or a bad spark plug wire. Reeds? Nah.
Just a few ideas for you to kick around....
Oh, by the way, there are 2 high speed jets, they just aren't adjustable. But again, one jet supplies two cylinders.
WillyBWright
I'm betting on a head gasket leak. Water is getting in there and extinguishing the flame.
