Re: 80 johnson v4 85hp timing issue
Got, it, using PB Blaster and working the timing plate back and forth i was able to free it up, now i will get some good white litheuim and lube it up. Thought at first i had a fuel or a spark issue, it would alway start but had a high idle after being warm, and the other symtom was it was had getting out of the hole, load up and die. Makes sense now, was easy to troubleshoot after figuring out, how it was supposed to work. If anyone else see this and whats to rule out this issue, just take off the hood, move the idle up lever and watch the linkage if the advance doesn't move with the butterfly's its sticking.
