80 Mariner Help!!!!!!
Jobsite
Just purchased a 1995 90 Mariner that has been sitting for about two years. I have pulled the carbs and cleaned as per Selco manual. I have put a new switchbox on the engine also. I have good spark at all spark plugs, I have good compression on all three cylinders, and the carbs are clean. I am at a loss, it will not even spit or try to fire. Does anyone have any sugestions???
Plainsman
Re: 80 Mariner Help!!!!!!
Are you sure your getting fuel? Sounds silly but.......
AMD Rules
Try tossing some fuel mixture or WD-40 in the plug holes, to assist. Will it fire then?
JUSTINTIME
satic time it also will help
try starting fulid with some oil in the cylinders
casi77
yah would suggest spraying premixed gas in the carbs ..and see if it attempts to fire up..
did you pump the fuel ball and does it stay firm? have you checked the fuel pump!?
Texasmark
Deep Creep spray in the carb while you are spinning the starter. If she lights off chase fuel. If not chase ignition. Just because you are getting it to the plugs doesn't mean that it is at the right time.
Deep creep contains oil and was made for 2 cycle engines as directed. Believe me, if it's a fuel problem she'll light right off with DC.
Mark
