rookie456
- Joined
- Aug 25, 2011
- 81
I have a 1980 80hp Mercury that I have rebuilt. I have been running the motor trying to link and sync and getting the carbs adjusted. The first three times a ran the motor in a tub, after I finished there was a black ring in the tub from unburnt fuel I'm guessing. The last time I ran it on muffs, and it left milkshake looking gray sludge out of the prop exhaust. I am wondering at what point does water and exhaust mix? I took the lower unit off and ran the engine with a garden hose feeding the water tube. Engine ran good, I stll had gray sludge dripping from the exhaust housing after I shut the engine down and shut the water off. I have checked the spark plugs multiple times for signs of water, but I only see fuel on the spark plugs.
Is the gray sludge normal at the prop, or should I be concerned. The exhaust ports under the lower cowl show no sign of gray sludge from there.
