aburch4384
- Joined
- Oct 5, 2018
- 24
I picked up a used (cheap) boat recently and wanted to test everything before taking it to the water. I tried starting the motor for the first time today and it fired right up but I had no water coming out of the tell-tale so I shut it down right away.
While it was running I did have some water coming out of the ports that are circled in green. Should I test this again with a tub instead of the muffs. The muffs are single sided and were 5 bucks at wal-mart. It looked like most of the water was just spraying out around them.
Obviously, I'm not too familiar with this stuff so I'd like to be sure there is a problem before I go tearing things apart. The model/serial number is 6e9 411129. Thanks!
