Just bought this motor from a guy who said he replaced the water pump impeller. I was able to run it briefly out of water and it started up and ran fine. I got it home and put the flush muffs on it and ran it. no water is coming out of the pee hole or exhaust. So I took the lower unit off. Sure enough, new impeller. everything looked like it was put together properly. I took the water cover off the head and it looks real clean inside. tried blowing compressed air up through the water tube from the bottom no air coming out anywhere it just pressurizes the tube and stops. Obviously something is plugged. Any ideas? do I need to remove the power head and start dissasembling it?
