Recently I did some maintenance work on my 81 Evinrude 25 HP; change all lower unit seals, replace waterpump & housing, new thermostat, and replaced the neutral start switch becuase there wasn't one on there when I bought the motor used. Long story short I got everything back together, did pressure & vacuum tests on the seals and everything was good. So I put the motor in a clean trash can full of water to test it out, and when I hit the start switch and as the starter was engaging and turning the motor over, after a few seconds there was this noise that sounded as though somewhere on the motor there was a release of pressure. As though as the motor was turning over there was pressure building up and after X number of revolutions some sort of gasket blew or something. It did this twice, so I called it quits with trying to get it started. Any idea what this might have been.
