When I removed the cylinder head I noticed that the bottom cylinder was dry compared to the top cylinder, so that led me to wonder what might cause the bottom cylinder not to get fuel. I read to forums, and read some posts that said it my be a stuck reed valve. So, I got to the read valve and checked it out. Not knowing much about them, I would say that were in good shape, none of them were stuck, and looked to be in pretty good condition. I assume the stop leafs are supposed to be curved, see photos below. Also, in the bottom cylinder the was a little surface rust, not bad, it wiped away with a rag and carb cleaner. Any idea where the water would get in.You can see on the reed valve that feeds the bottom cylinder there is a little rust as well. FYI I am in the process of replacing the head gasket and exhuast manifold gaskets. Your advise is greatly appeciated.
