MarshMan73
- Joined
- May 21, 2009
- 53
My friend's 81 Evinrude 35HP is causing problems. It won't plane out now, but idles fine. Starts everytime and idles beautifully until you try to get up on plane. It just makes a loud wah, wah surging noise and stays low rpms. It is using about 5 times the amount of fuel it normally takes to get to his camp. He has checked the float level, primer bulb, fuel hoses and filters, pulled the fuel pump and checked. Has tried adjusting timing settings and nothing works. He does say that if he puts his hand over the front of the carb it picks up and starts running better under load (boat tied to dock in gear). He has pulled the main jet and cleaned and rebuilt the carb, but still has this problem. Is this a carb problem or could it be ignition? We have tried the pull each plug and see if it runs test and it will run on each plug by itself.
