81 johnson 75hp linkage problem?
mattsylvan
i had my boat out on friday to test the motor and i still cannot throttle it wide open with out it stalling out but when i press the choke in once the motor gets up to speed and i can run it at high rpm but when i take from forward to neutral it doesn't shift into neutral the idle lever kicks up and i can control the speed from the idle lever and then i can get it to idle for abour 4 seconds then dies.
