So I picked an 81 johnson 90 horse v4 last year and had it out once. it ran alright other than dropping a cylinder (bad coil pack) every once in a while.
I had a finicky idle and hard to start without giving it a lot of gas.
Did a comp test and had a wide range of readings from 80 down to 30. So I was going to re ring it. Pulled the head and the bores look great with no damage to the walls or the pistons so I figured I could get away with a re ring.
I did this on a previous force 50 i had by pulling the carbs and reed plate and getting to the connecting rides from the back side. I just did this on this johnson and it is not possible. I already know the answer but anyone have any other way of getting the pistons out without removing the powerhead and splitting the block? A lot more work than I wanted for a boat I have to sell.
