ryanorillia
- Joined
- Mar 28, 2015
- 28
while it's out i figured i'd change my prop seals--
my question is:
are part #'s 7, 2, 4 and 3 INSIDE the bearing carrier already? when i took it off the only loose part was #32
i'm assuming #53 is already mounted in the prop as i didnt see any loose pieces for that either?
also there was no oring behind the bearing carrier, just that black seal ring you can see on the back of the carrier in the picture.
the back of the bearing carrier seemed a little rough and pitted in spots I just want to make sure i'm not missing anything
thanks
my question is:
thanks
