81 Power Trim and Tilt evinrude question...
mrracer98
So I have searched and not found what I am looking for... This TNT worked last time motor was used but that was 3+ years ago, it has sat sideways for a while (motor was laying around) Now I go to use it, it does not work.
I need to know how to drain and refill this TNT... Here is what I have done...
Drained out old oil, opened relief valve (which had a bad O ring I replaced) opened up the valve on the port side lower aspect of the TNT when draining it. (Cycled it open to get the oil out) Replaced it, shut the manual relief valve, filled the resivior.
Motor would not cycle, so I cycled it manually several times. Cycled a couple times, very slow and jitterly via the TNT, then it just stops like it cuts power to it from a high or low pressure shut off.
Is there a proper order to close the valves or drain the oil? I am at a loss as the manual says nothing about the actual process of doing this. faulty component?
PS I used Dextron III ATF.
Please help! Thanks!!! :confused::confused::confused:
