82 70hp johnson needs help
rmpenton
i bought a 82 johnson 70 with trim and tilt.the trim motor has 2 wires comming out of it.does anyone know where i can get a relay box,or know how to make one.any help is appreciated.
Hooty
Re: 82 70hp johnson needs help
Here's how it works.<br /><br />
<br /><br />c/6<br /><br />Hooty
Cut n' Jump
If ya can't find that box or don't want to spend the bux just make one. Power windows in cars work the same way. Get a power window switch for a car and it should work. The object is to reverse the polarity. You could also wire up an on/off/on momentary switch to a couple cheap automotive relays and get the same result.
