82 Johnson trim
Smitty74
Have an 82 Johnson 75hp, am missing relay box and all wiring except wire from trim control on throttle. It is a three wire set up and everything I find to replace box and wiring is two wire. I find a few boxes without wiring on eBay but no complete set up.
I find some part #582192 available which look to be the complete set up and only one part # off but show a two wire when I look. There are wires coming off pump but wire is clipped. Look to be 3 wires there as well.
Anyone have a source or part# for a replacement ? or a work around?
Model # J75TLCNB
Any help would be much appreciated.
Your trim tilt may well be an older unit.----So does your trim m0otor have a blue and a green wire ?----Or blue , green and a black wire ?
Smitty74
Now that I I think about it, those were the wires attached to the control. Not sure about the ones on the motor. I'm not at home. Will have to check on that when I get home. Could number of wires be different?
Sorry.-----I am asking you to provide information so that you can get help.----Earlier trim motors had 3 wires and later ones had 2 wires.-----I can not see what you have !
