Re: 82 Mariner 90 HP Impeller change out
These motors are simple to remove the gearbox, 6 nuts, one under the trim tab(remove that with a 1/2" socket. then the box will drop away. 3 nuts and a bolt for the water pump and presto, one impeller. Installation is the reverse but getting the shift shaft lined up can be difficult. Good luck.
