Can a bad trigger make a motor cut off when i put it in gear in the water only?
B brennadnky Recruit Joined Jul 10, 2009 Messages 5 Aug 17, 2009 #1 Can a bad trigger make a motor cut off when i put it in gear in the water only?
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 28,545 Aug 18, 2009 #2 Re: 82 merc need help Normally that is a carb problem. Did you mess with the carbs?
B brennadnky Recruit Joined Jul 10, 2009 Messages 5 Aug 18, 2009 #3 Re: 82 merc need help i rebuild the carbs changed switch box and stater
