I have an 82 OMC Stern Drive 5.0L, I justed put in a brand new gas tank and fuel lines. New plugs, filters and oil. The engine starts right up on the first crank, the engine idles fine no sputter at all. Last night is the first time I took her out on the water and as soon as I left the dock and gave it about half throttle she started to bog down. If I let off on the throttle she would run ok at very low speed almost at wake speed. Then once I gave it more gas she would bog down and back fire through the carb and seemed like it wanted to shut off.
I have not taken my carb off yet, but to me it seems like the carb is probably all gummed up and clogged. I have rebuilt the carbs at least twice a year ever since the ethynol issue in the gas. I am running an Edelbrock 4 barrel carb with electric choke.
Is there anything else I should check before I take apart my carb again.
