Mark Nagel
- Joined
- Jun 8, 2009
- 6
OK, the water jacket cover and baffle plate looked fine. Carbs are rebuilt. Compression is 125 +-3 psi on all six cyl. I just started the electrical diagnostics and may have found something. Stator test one of the readings was 5300 (ok range is 5400-6200 ohms). I also found two corroded yellow wires connected to my rectifier going to the stator. I re-wrapped the wires, no change. Any suggestions and do you know were I can find a stator and maybe a rectifier?
BTW, at the launch today, I can get full revs with the motor/prop almost out of the water (low load) when I tilt it down adding load it bogs down right away. Just like if I start with it full in the water, can't get it to rev up.
Mark
Mark
