txbandit44
- Joined
- May 11, 2008
- 182
OK today I took the boat out and before i trailered the boat to the lake I had to add TnT fluid. Got the boat in the water and after about an hour of running around i noticed an oil slick following me around. The trim also quit working. After i got it on the trailer i had to open a large screw plug just below the motor and lift the motor by hand. A the fluid comming out was milky. I think the problem is on the main tilt ram seals since it has a greasy sludge on the top around the ram.
Would the BRP seal kit fix this? Are there any surprises to look out for while servicing the unit?
