The motor is a 1983 ELCTS..... last year i put new brushes in the starter since the leads came off of 2 after inspecting it when it would not start or turn over..... Starter worked fine all summer last year..and near the end it started to squeal and drop out of turning the motor at times ....
This year I tried to fire it up turned slow and squealed again and dropped out from cranking all connections were cleaned batteries are at full power 13.6 volts I lubed the shaft on the bendix ....if I hold the key it will make 4-5 revolutions and bendix retracts and squeals ..when i did brushes i cleaned whole starter in side with electrical cleaner and lubed all the shaft bushings.....what gets me is it worked great for the summer till fall came and this all started on me and is here this year also....
Any suggestions........all ears
Alan
Alan
