Where are the reed valves located on a 1983 40hp twin cly single carb merc
S sea-ray steve Cadet Joined Jun 2, 2011 Messages 23 Dec 21, 2016 #1 Where are the reed valves located on a 1983 40hp twin cly single carb merc
Chinewalker Fleet Admiral Joined Aug 19, 2001 Messages 8,902 Dec 21, 2016 #2 The reed block houses the center main, mounted on the center journal of the crankshaft, sandwiched between the crankcase halves.
achris More fish than mountain goat Joined May 19, 2004 Messages 27,468 Dec 21, 2016 #3 Number 9 are the reeds, which are screwed to number 5, the reed block/main bearing, which goes around the centre of the crankshaft. If you need to replace them, it's a full engine disassembly. Chris.....
