I was working on my Johnson 7.5HP today. I changed the head gasket and used some sealer. Put in also a new thermostat kit and once all done I test it in the 60 gallons drum.
Motor did not work good for long, it started getting hot fast even with a good stream of water coming out from the pee hole. I shut it off, once it got to hot on the head before blowing up the new head gasket.
Got the tstat off and it ran #1, strong in gear and a good idle . But is this ok if I will do a lot of trolling with my new inflatable boat. I have a 4.5HP Johnson and they dont run with one.
By the way, the impeller is new also. What can cause this?
