Hi,
I am hoping someone on this forum can help me. I wish my grandpa was alive :-( I could just ask him - he worked for Evinrude for 40+ years. I just purchased an 83 75hp. The previous owner ran out of patience, time and money trying to fix a hard starting issue. I am not a mechanic, but through this and other forums, I think I have it narrowed down to a carb/float issue, needle adjustment issue or a timing adjustment issue but I would like to narrow down what to buy next - carb kit or timing light. I don't know how to adjust the little screws if that is what it is. Or maybe there is something else?
The motor has good compression, good spark. The plugs, fuel lines, filter, and bulb are all new. The primer solenoid seems to work ok. On muffs the motor starts way easier presumably due to no back pressure?
Here is my starting ritual:
1. Pump bulb
2. Push in key and turn over
3. Motor tries to fire a couple of tries
4. Stops firing - just spins
5. I turn the red lever to manual
6. Turn over - tries to fire again but won't start
7. Turn back to automatic
8. Motor fires and starts otherwise repeat from 3
9. Idles rough - must keep idle high or dies
10 Engaging gear nearly kills motor
11. Once moving she runs great
12. I shut it off same problems to start again even fully warmed up
Thanks in adance
1. Pump bulb
Thanks in adance
