Need to replace the impeller on my B100. All posts I can find refer to disconnecting the shift shaft by loosening a "locknut" midway down the housing. My shift shaft runs through a solid housing and is "invisible" all the way down. Can anyone offer the procedure for disconnecting the shift shaft on this motor? Should I disconnect at the top of the shift shaft?
Thanks for your input.
Backlash
Backlash
