83 Evenrunde 150 no water out of pisser
overtheedge472
I recently picked up a 83 Evenrude 150. I got it home fired right up no water out of the pisser. So I did a water pump replacement still no water out of the piser. Pumps water out of the lower unit slots just fine. Ran motor for about 5 mins. No water out of the pisser but the heads were nice and cool. Not hot at all just warm like I would think it should be. This is running off a hose set-up. Any ideas what could be going on here. I think I got everything lined up fine. It is running like a champ except for that.
85 BOMBER
Re: 83 Evenrunde 150 no water out of pisser
Have u tried compressed air in the pee hole? Could be stopped up??
overtheedge472
I will give that a try. I don't think it's stopped up but anything is possible.
Will Bark
If air doesn't work run a length of weedeater line up the hole maybe a mudbug built a nest in there.
overtheedge472
You guys nailed it a little bug clogged it up pretty good. Now we have a nice solid stream.
Thanks
