83 Evinrude 25 kill switch prob.
58 Alumacraft
My 83 Evinrude tiller has problems shutting off, if you push the kill button on the front of the motor at idle it will spit and sputter for at least 5-10 seconds and finally die. If there is just a slight twist on the throttle (increasing the RPM's) it won't even think about shutting down. Is this normal? I have removed the rubber boot on the kill botton and found the contacts to look very clean. Any ideas? Thanks!
