Hey guys, for anyone following my motor progress, I just found another issue with the choke solenoid, doesn't work at all with key switch (I dont hear it clicking when I push the key in). I did the an ohms test across the solenoid (as per service manual), tested good, and ran 12v to it and I can here it clicking, so I think the solenoid is good.
So I think I have a wiring problem somewhere else. I decided to start with the main wire harness inside the cowling before I even test the switch in the control. My wiring harness is a mess, i had to repair about 8 wires due to mouse damage When i use my continuity tester between the positive on the solenoid and each pin on the harness, two different pins sound off (pictured), which seems odd to me. But weird thing is, if I put 12v to each of the pins, oddly one seems to be the starter solenoid (which I can hear clicking) and the other doesn't seem to do anything. My harness may just be toast, but I'm not that eager to pay $100 for a new one. I'm wondering if anyone has any ideas on how to track down my issue.
