Having trouble locating a piece located underneath the inner exhaust manifold that is bolted to the block. The function of it seems to direct exhaust into the manifolds smoothly, one for each side of the motor. Right side is broke. Can't find it on any parts breakdown. Noticed a water leak coming from the manifold is how I found the piece inside broke. It was obviously already broken when I bought the motor, only had it for this one summer and has been running fine except at idle. Would have a sneeze come out of the right hole on the back of the motor where exhaust comes out above the water line. Also could this water leak inside the motor cover cause me to receive a powerful shock at the controls because it felt like I stuck my hand in a 220 outlet when this happened
