'83 Johnson 235 - Erratic Idle
ob1jeeper
Help... Have been chasing poor idle & starting difficulties since January... Am at my wits end, and this Johnson 235, is about to become a "Davey Jones Locker inhabitant".<br /><br />EVERY SINGLE PIECE (I mean EVERYTHING...right down to the hose clamps !!!) of the fuel system is either FACTORY N.O.S. (new old stock), NEW, or COMPLETELY REBUILT (professionally... not shade tree stuff...)<br /><br />On the hose (in the driveway at home) it runs like there is absolutely NOTHING wrong. AND When it is first dropped into the lake, it starts & idles almost as sweetly as a fuel injected motor. HOWEVER... As the day wears on, the harder it gets to start, and the lower/(and more erratic) the idle speed becomes, until it's idling so slowly/poorly, that WHEN it finally starts, it's hard to keep it running long enough to get it into gear... Here's the weird part... once you're in gear, it will purr and idle/troll for literally HOURS with ZERO problems, until you shut it down, and decide to re-start 5 or 50 minutes later...<br /><br />A few weeks ago, I thought I had it licked, but what was supposed to be a week on Lake Powell, (where the wind was trying to constantly blow me onto the rocks, when it died... GREAT FUN !!!) convinced me otherwise... I finally threw in the towel, and came home WAY earlier than planned...<br /><br />I REALLY need some help on this one, as both myself & my local dealer have spent literally HOURS/DAYS/WEEKS/MONTHS trying to diagnose & fix. For a few hundere more than what I've spent, I could have nearly had a brand-new FICHT... If only I'd known then, what I know now...<br /><br />Is it possible the timing base plate is loose/shifting, causing the erratic idle speeds? Also (and on an errattic basis) it's "sneezing" at idle (which I've been told is a sign of fuel misture being too lean... but I'll be double darned if I can figure out why or how that is occurring...)<br /><br />ALL replys are appreciated... I can't believe I'm the only one who has ever had a "possessed OMC 235" ...
R. Wood
Re: '83 Johnson 235 - Erratic Idle
If you are running lean @ idle, you can decrease the size of the idle air jet.<br /><br />This will richen the mixture by allowing less air and more gas/oil @ idle.
ob1jeeper
Thanx for the idea... But wouldn't that correct a problem that is ALWAYS present at idle? (as opposed to an idle and hard-to-start issue that only occasionally rears it's ugly head?)
R. Wood
Sorry, I couldn't be of more help.<br /><br />I thought I'd throw my 2 cents in, due to the fact the responses to your quesiton had been sparse.<br /><br />Maybe your intermittenly dropping a cyclinder.<br /><br />Good luck.
ob1jeeper
Mr. R. Wood... Thanx for your concern about getting minimal replies... I too was abit surprised by that, but so be it...<br /><br />Anyway... I think (more like pray) I've found something worth chasing around a bit... Seems the plugs are also fouling pretty qwuickly (maybe because I troll it a significant amount...), and if this thing were one of my old dirt bikes, I'd simply lean out the fuel/oil mixture a bit... (but I DARE NOT go leaner thna the 50:1 I'm already at), OR... I'd go hotter on the plugs... However, my local certified Evinrude/Johnson boat mechanic is not at all happy about that decision, as he's afraid I'll melt it down, because I can't hear it spark knocking...<br /><br />Gonna try anyway, and be VERY cautious about how hard & for how long I push it... Wish me luck...<br /><br />Thanx again...
