powers laker
- Joined
- Jun 21, 2012
- 10
is this normal or is motor overheating,Water temp on the lake is 74 degrees
More than likely although I have adjusted shifting linkage once before on my fishing boat,for some reason,it is down also,no spark then spark issue,but now that I have found this site,I have seen some threads that might help.I bought a 101 lb thrust trolling motor so at least I can still get around our lake happily.Awesome site.Now its time to make the donuts!!!Slowly turn the flywheel when pushing up the gear-case and it will align.
Guess your next problem will be to adjust the shifting?
