'83 Johnson 35HP...Help...I'm Stuck!!!
BigBankWA
This motor is on back of a 15' 1984 Tiderunner Rnbt that I bought last week. Previous owner had let set for 4-yrs after it broke down on him. I opened it up and found the number one piston has a hole in it. Started the tear down and ran into a couple of minor (lol) issues.
1. RE: Gear Case/Engine: I have the externals all removed. The four bolts from under and the two nuts from up top removed, but the motor will not seperate from the leg. I have the manual, and have followed it to the "T's" and after removing these 6 items...it says to "rock the motor until you break the seal". Well I have rocked that sucker to no avail. What could I be missing?
2. I moved on to the lower unit so I could feel some sense of accomplishment. I disconnected the one nut and two of the four bolts. The other two bolts broke off just below the head...but since they are not threaded into the lower unit I do not see how these will keep it from disconnecting. And yes, the shift linkage behind the water pickup is also disconnected...yet the lower unit laughs at my attempts to seperate it from the leg. Literally it does not budge.
Any help or guidance would be appreciated. I have worked on my own outboards for years, but never to this level.
Whoopbass
Re: '83 Johnson 35HP...Help...I'm Stuck!!!
You trying to pull the powerhead off? If so your going to have to use a prybar and pry the **** out of it but be careful not to break anything.
The drive shaft on the lower unit is probably frozen inside the powerhead.
You might think about parting this outboard out instead of rebuilding it.
crxess
Sounds like the down shaft is stuck.
Put 2 bolts loosely into the lower unit.
Remove all spark plugs.
Using a breaker bar and proper socket on the (Tightened) Flywheel bolt, Shake the flywheel/crank back and forth vigorously.
jonesg
A deadblow persuader , or 2x4 and a BFH.
I like 3 lbers for persuading stuck parts.
