Re: 83' Johnson 90 mod to 115 specs?
Dhadley,<br /><br />Thanks for the input. I guess I should have been clearer in my 1st post. I bought this engine and boat and knew it had 1 bad cylinder when I bought it I have never actually run this combo. The prior owners setup looks fine as far as prop etc. It probabally was a lean condition I'll address later if I use the 115 carb setup. Now back to my original question. Is there a difference in carbs from the 90 to the 115 or did they just run different jets? Also does anyone know if the porting is different between these two engines? I have alot of experience building performance marine engines, mainly mercs, but really don't want to tear into a good running 90 and have to rering etc, just to modify the ports. Thanks again.<br /><br />Zane
