I bought an '83 Johnson 140 hp with my boat. When I first used it, the trim worked fine. After we put it in the water and ran it, we pulled the boat back out and the trim will not work now. I can hear the motor working in the trim, but the engine is not moving. I tried adding fluid to the trim, the two hydraulic valves started moving up and down, but the engine still did not give way. I've come to the conclusion that the problem is in the hydraulics and not the electrical because I can hear the motor trying to work. But, am not sure. I would appreciate any help I can get on this, before I have to spend hundreds to fix it...Thanks!!
