Re: 83 merc 150hp bog down
Been there, done that. 88 150 XR4 on a bass boat. Bought it with the problem.
I found.
Warped valves in the fuel pump.
rebuilt
Fuel pump pulse hose was soft.
replaced
Carbs set sloppily. (probably not significant)
rebuilt and carefully set up.
Chit in the fuel that repeatedly plugged the fuel filter.
Cleaned fuel system and installed Racor filter/water seperator
Discarded stock fuel filter.
Primer bulb and hose aftermarket substandard
Installed OEM parts
And the one that took the last little bit of hesitation out
Aftermarket plastic bayonet fuel connector
Bypassed, ran hose directly to fuel/oil mixer.
Most of this was found by installing a fuel pressure gauge between the fuel filter and the carbs. Pressure would run up to 7 lbs running, and fade out to 0 when the problem occurred. Anything over 2 and below 7 is fine.
Starving at WOT is probably the most common initial failure causing melt down of pistons. Get it fixed or you will be unhappy.
hope it helps
John
