83 mercury 25hp carb/please help!
blw270
I need help asap. I have cleaned the carb and am attempting to replace all gaskets but I have some in the kit that I do not see in the carb. I just got this engine and the guy told me the carb needed work and that he had tried cleaning it. He had used formagasket instead of the real thing so I am not sure where two orings go and I also think there is a needle valve missing. If you can help, please call Brian at 662-315-3623. I need to get this engine going by friday if possable. Thanks in advance. ------ Ok, I have looked again and again and I just don't see where they go. It is one o-ring about 1/4 inch diameter and one hard gasket just a touch larger. Can some one explain where they go? If not, please call. Also, how many needle valves are on it? I have only one but there is a hole beside it that looks like it should have one as well.
blw270
Re: 83 mercury 25hp carb/please help!
Thanks Laddie. That helps a lot. I do need all the gaskets and now I know where they all go!
