INDYCAVER1
- Joined
- May 15, 2010
- 51
You guys go any suggestions on what to look for on my issue. I did compression check today and all 4 cylinders were 115-120. I finally got the tachometer working and me and my daughter went out today and at wide open throttle we were only running 2900 rpms. I took the carbs off and cleaned them and put new fuel pumps on both. I havent put them back on to test them but should have them back on to test it later this week. If I know the compression and fuel are good,. What can I check next. The motor is on 15 ft tri hull hul the prop is 11" x 13 pitch. Could it be the prop?
