'83 Suzuki DT25 ..... Dilem***
blkdgbts
ok, I couldn't get this motor to run at all. Now it'll start if I pull start it, but won't if I try to start it using the electric start. I checked the voltage drop on the battery as the starter is running & it drops from 12.45v to 11.55v. again, if I pull it it starts like a champ. As always, any help is greatly appreciated.<br /><br />r -
metredwards
Re: '83 Suzuki DT25 ..... Dilem***
Hi,It sounds like your ignition switch is not feeding power to ignition ciruit while in the start position.Hope this helps.
rickdb1boat
Have Battery load tested at local Auto Parts store!
