triplehooked
- Joined
- Dec 28, 2009
- 30
I recently purchased an 83 Bayliner Capri 1950 with the AQ125A engine and 270 outdrive. The po claims it will go 35-40mph but I think that is pushing it. The first time out on the water the prop was slipping, so I had to pick up another. I found a used prop at a local shop and the fella gave me a 14x18 aluminum three blade. I'm concerned that this is a little too much prop, but the PO was paying for it so I didn't complain. I will primarily be using the boat for tubing with a family of 6, so I figure the load to be close to the max of 8 people/1200lbs. Will this prop be too much? I was originally thinking a 14x15 but the shop didn't have any used. I don't know the rpm's of the motor with this prop as I haven't tried it yet. I don't want to be lugging the motor....
Question #2 What gear ratio is this outdrive? And how do you break the serial #'s down?
Here are the part #s
Engine AQ125A 7679010468
Transmission 850676 8302 241624
Outdrive PZ NR 27113361 D
As always, thanks a bunch for your time!!
Travis
Travis
