chucksjunkyboat
- Joined
- Oct 21, 2005
- 5
Iam reworking my 35 after I wrecked on the highway. I have a few question.<br /><br />This motor has an elec primer.<br /><br />I do have manuals but cant find the information i need.<br /><br />1. i need to know how the fuel lines run. is the primer line before the fuel pump or after.if its after does it tee with one line going to the carb and the other to the primer?<br /><br />2 does it matter which primer line goes to the carb andthe other to the motor (these are the very small ones)<br /><br />I have the lines from my motor and my parts motor. iam going to use new hose but I have all my fitting<br /><br />question #2 I need the fitting (i dont know the name of it) that screws into the water chamber, it has a hose that connects to it and then runs down to the pee hole. are the threads standard NPT? can I get one from tractor supply? what is the proper name for this fitting? <br /><br />Thanks, Chuck
