Hello,<br /> <br />I have an '84 evinrude 35 E35ELCRR and I have a couple of questions. <br /> I am going over the carb again cause the engine is running a little rough. It has just been rebuilt, it appears there is way to much juice going into the engine. My manual says the float level should be from 1 1/8" to 1 5/8" from the bottom of the carb to the bottom of the float (holding the carb the right way up). This is a pretty big tolerance.. What is peoples experiences with the float level setting? What measurement seems to work best?<br />Also this model has the automatic choke. There is a red lever on the solenoid, what does this do and where should it sit during normal operation? There is no reference to this in my manual apart from showing how to disassemble and assemble it. <br /><br />cheers<br />mike
