Re: 84 Evinrude 35hp
Mornin' Micar,<br /><br />I've got to presume that since you've rebuilt, you have a manual. Assuming this is true, I have to expect that the manual suggests "Break-in" procedure for NEW or Rebuilt engine.<br /><br />I expect that it will suggest doubling up on oil in premix for the first tank or two. I would also expect that it suggests not running at WOT right away, but run intermitantly at medium and low revs. <br /><br />It may then suggest to retourque the head bolts after one or too "Break-in" outings.<br /><br />Regardless of what I think it may say. stick around. I'm confident that somebody on this forum can give "By-the-book" recomendation for this motor.<br /><br />By the way. Congrads on the successful rebuild.<br /><br />What was the motivation for the rebuild? New Rings and Bearings, old pistons and bores OK? Curious.<br /><br />Good Luck<br />HAVE FUN
