Motor is surging above 4K rpm. I have cleaned the carbs, tightened all fuel fittings, replaced tank with known good tank, inspected fuel pump screen filter and diaphram and made sure of fresh fuel. Spark test under load shows good spark, compression is even at 100# in all three, choking does not help and the bulb stays firm. I'm at my wits end and am going to look at a 93 model 60hp tomorrow but I want to make sure I'm not overlooking something simple.
I have never adjusted the timing but the advance linkage moves freely with the throttle. I did notice the flywheel had a small amount of play. My only guess now is a worn main bearing and seal causing a vacuum leak.
Any ideas?
Any ideas?
