I've checked comp. Changed plugs and powerpacks. Motor idles fine. But in gear it will go no faster than idle speed. I pulled plugs and checked them one at a time for spark. All good. Here's where I'm dumfounded, while the motor was running, I pulled both plug wires on the port bank and it did not change the running condition of the motor at all. How can the plugs be firing but not hitting in the cylinder. I need expert advice. Forgot to mention, the motor has developed a bad sneeze in low idle that will usually kill the motor
