I have an 84 Johnson 30hp and can not get it to pee while submerged in trash can of water, ran engine about 2 or 3 minutes, getting very light mist.
I have replaced the water pump (made sure key was correct, and turned shaft clockwise while installing), I checked the water pick up tube by running water through it (no clogs), and I blew 80psi of compressed air into the water pick up tube when connected in top (very very low air pressure was felt coming out of the 2 little exhaust ports).
Could the water jacket be clogged? How would I check this?
Could the thermostat cause this?
Thank you
Thank you
