The motor starts easy enough, but it just won't throttle up all the way like it used to. If you punch it it will get to about 3000 rpm and act bogged down. If you keep bumping it it will eventually get up to 3,400 rpm and on a plane at about 20mph, but it if you go too far it will bog back down. When I spray carb cleaner in the bottom piston it will take of like a banshee and do the 4000 rpm and 35 mph like it used to do, but carb cleaner is a little expensive to keep that up. I'm wondering if its the high speed jet but i have taken it apart, and thought i cleaned it out pretty well. Does anybody have any experience, or suggestions? Thanks.
