I have a 1984 Johnson 70 that was reading a bit low (125, 120, 95) in the lower cylinder so I pulled the cylinder head cover to figure out what might be the problem. The 3rd piston, which had low compression, is slightly damaged, and all the pistons were fairly dirty. The cylinders themselves appear to be in fairly good shape, no scuffs or abrasions. What is the best mode of attack to fix this, just take the piston out and replace it and how should the pistons be cleaned? The carbs appeared to be in good shape, but they are being taken off and cleaned. Also I have ordered a omc manual to help
