I have an 84 johnson 9.9 sailmaster electric start that has a problem I have been chasing for 4 months and I need some help. The motor starts fine, idles fine and runs ok through about half throttle. At higher throttle it begins to run terribly and bogs down and quits at wide open throttle. I have checked resistance on all coils under flywheel, checked resistance from coils to their components (all ok). I replaced the power pack and swapped ignition coils with known good coils. Spark plugs are new. I have replaced both tank and fuel line connector to motor as well as bulb. I replaced fuel line to fuel pump, replaced fuel pump and overhauled carb. I have noticed some fuel spitting in carb which is a symtom of a reed problem. My question is will a reed problem cause running problems at mid to wot?
